http://board.homeseer.com/showthread.php?t=170141
Bedford, NH (PRWEB) September 05, 2014
HomeSeer unveils its line-powered HSM200 Z-Wave multisensor - night light - indicator module. The unit senses motion, temperature and light level, can function as a night light, and can also be programmed to display up to 7 different glowing colors when things happen in the home!
Since the HSM200 is line powered, there are no batteries to change and the unit automatically operates as a Z-Wave network repeater. Installation is fast and easy. Just plug into any available 120v outlet and tap the button on the side to join it to your Z-Wave network.
HSM200 is compatible with any HomeSeer HS3-based system, including the full line of HomeTrollers. HomeSeer users can create events to display different colors when motion is sensed, doors are opened, water leaks are detected or just about anything else happens in the home. Color options include red, green, blue, yellow, magenta, cyan and white. The unit can also be programmed to work as a night light after hours.
HSM200 is slated to begin shipping in October and will retail for $69.95. Dealer inquiries are welcome.
