Misplaced my AC adapter (or I should say, it got thrown into a pile of other adapters and lost it’s identity). Can anyone confirm the output voltage/current/polarity ? As I recall, it was 12v/1amp/tip positive, but I don’t want to fry the thing due to a silly mistake. TIA.
which Vera? Which country?
Vera 3 and Lite input in the U.S. is 12VDC 1 amp with center pin positive. It should also indicate the voltage/current requirements on the label at the bottom of the unit.
It’s probably the same for other countries as well, but I’m not positive that there are no variations.
You’re absolutely right, never looked on the bottom label, thanks. The mind is the 2nd thing to go, I forget what the first thing is…
