In the past, with my Schlage lock, I was able to use pin code 0 to catch all valid “pin code is entered” in the notification. Now, it does not seems to work anymore. Since I’m using it to get notification when guess arrive, I have to program and delete it with every new pin code creation and deletion. Is there a better way?
Try using * instead of 0. Is this UI5?
- Garrett
Thanks Garrett. I’ll try *.
This is vera2, I believe UI4?
Not sure if that will work with UI4. I know this is what is used for UI5. I have not been on UI4 in a long time. It is worth a shot though.
- Garrett
I’ll give it a try and update the thread if it works or not.
