[quote=“robertloll1, post:3, topic:174592”]I have installed a very basic Honeywell Ademco Vista 20P system which I run wireless using:
1 Vista 20P Panel rev.9.12
1 5883H High Security Transceiver Module
1 6160 Wired Alpha Keypad (for programming)
2 5828V Wireless Fixed English Keypad with Voice
1 NuTech AD2USB Adapter
1 EnvisaLink 3 TCP/IP Module
3 5820L Slim Line Transmitter (wireless magnetic door sensor)
1 5815 Wireless Door Transmitter
1 5816 Wireless Door Transmitter (coupled with ALEPH PS-2023 Overhead Door Contact for Garage Door)
4 5800PIR-RES Wireless Passive Infrared Motion Sensor
In addition, I have a Schlage z-wave door lock, which I love. I am going to be installing some 5800PIR sensors (not 5800-PIR-RES) which allow for downward looking infrared and other advanced features.
My Vista 20P system is entirely wireless except for the 6160 wired alpha keypad, a single 4-conductor cable, and a Cat 5e cable running from the Vista 20P cabinet to my VeraLite system and router. The 4-conductor cable connects to the NuTech AD2USB Adapter which connects to the USB port on my VeraLite. I run the Honeywell Ademco Vista Alarm Panel AD2USB plugin to interface my Vista 20P panel with VeraLite through the NuTech AD2USB Adapter. You have to have at least one wired alpha keypad to program the panel.
I really like the EnvisaLink 3 TCP/IP Module, which I run directly to my router and can use even if the VeraLite is down for some reason. The maker, EyezOn Corporation, provides a free website which can be accessed to control the Vista 20P panel at any time. The panel can be armed and disarmed, etc. over the internet via both the VeraLite MiOS web connection and the EyezOn Corporation website
I used to run various z-wave door and motion sensors with VeraLite, but now I only use the VeraLite for lighting and AV control (using SQBlaster from Square Connect and the associated SQBlaster plugin). With the Honeywell Ademco Vista Alarm Panel AD2USB plugin, all of the wireless Honeywell sensors, both door and motion, can be used to trigger scenes. I can use my 5800PIR-Res motion sensors the same way that I used to use z-wave motion sensors. I find that the 5800PIR-RES sensors have much better battery life (years vs months) and better reset and stay-awake times without compromising battery life. I have used Intermatic CA9000 and related motion sensor as well as Aeon Labs Aeotec, Hawking HRMD1, and HSM100 and related motion sensors. The response time of the 5800PIR-RES sensors on VeraLite though the plugin is acceptable. I have read that the response time for wireless motion sensors on a Vista 20P panel to get a signal to the VeraLite system can be a matter of minutes, but that has not been my experience.
I am very satisfied with the Honeywell Ademco Vista 20P panel with the 5883H transceiver module. It would be nice if the plugin had a virtual keypad and if specific keypad sequences or numbers could be used to trigger scenes like the Schlage z-wave door lock can, but you can?t complain about free software that works very well.[/quote]
Does the envisalink 3 allow you to use the sensors in the scenes?
