I knew I was tempting fate, but stupidly I upgraded after a couple of weeks of Vera operating properly with 0.900, and low and behold, scenes failed to turn off lights this evening. Oh well, guess it was my own fault, upgrading and all…
0.900 was stable for me and I had no issues with new dongle for over 3 weeks. Upgraded to 939 yesterday and that is the version that just failed for me tonight.
I experienced a similar problem after upgrading to 939. In my case, because this upgrade followed a complete failure of my entire system, where I had to reset Vera to factory default and rebuild my network from scratch, I sort of forgot about the scene timer failure after everything else was working again. But now that I see this thread, I was reminded that my “Sunset” scene timer stopped working. Perhaps a bug in 939?
Sunrise and Sunset scenes both worked properly today for me. Must have been some sort of glitch.
Strangely my log from yesterday did not show any failed commands, but none of the 5 lights that are turned on after sunset were shut off, I shut them off manually close to midnight.
Here’s hoping this was just a small anomaly for me ;D
We thoroughly tested this for 939 and can’t find any problems with scenes and timers so it should never miss a scene, and if it does, it’s our top priority to fix it. If we have logs to indicate what happened, we can identify and fix it immediately. So if anybody is having a similar problem I recommend this: Go to Advanced, Logs, and check ‘Verbose Logging’ and ‘Lock Log Levels’. Then the next time it happens, go to Advanced, Tech Support and submit a trouble ticket with ‘for Aaron’ in the comments, and indicate which scene didn’t run at which time. We’ll look into it and reply right away.
IMPORTANT: If you check Verbose Logging, the verbose logging turns itself off automatically after 24 hours unless you check ‘Lock Log Levels’, which locks verbose logging on. Remember to uncheck Lock Log Levels once you’re satisfied it’s working (a few days tops), otherwise Vera will be constantly using a lot of bandwidth to upload the large, verbose logs, and this constant zip’ing up and sending files will make Vera run a lot slower. But, it’s the verbose logs that have all the detail we need to know exactly what went wrong.
Idiot alert (me, I mean)…after I reset/rebuilt everything this weekend when my scene controller kluged up the whole network, I forgot to go back and set my location (country,state,city, etc.). Duh…no wonder my sunset timer didn’t work. Oops…
Most days my Vera seems to miss scenes all together
On days when the scenes work only half the actions in the scene actually happen
All of my devices seem to work perfectly when I turn them on/off through the Device screen.
Every day or so Vera hangs and goes into a mode where it is pingable, and you can sometimes get SSH access if you wait 10-15 mins. In this mode it won’t fire any scenes. It seems that if I reboot Vera, and do NOTHING to it, then it won’t hang for a couple of days. If I open up the GUI, then close it, Vera will hang a few hours later.
If I enable Verbose logging, and lock the levels, then Vera crashes after an hour or two and then you cannot retrieve the logs.
Is MCV still reading the forums? I hope they are working on something big.
I’m not sure if upgrading would fix your problem since we still don’t get a list of bug fixes and feature changes/additions. And we really don’t know what is causing your problems anyway. Since the upgrade was quick and easy for me, and didn’t seem to cause any regressions, I can recommend it. Who knows what it might fix?
Funny you refer to “announced” version. That’s 939 but until someone posts here we don’t really know what is the latest beta version that’s been posted. I think LibraSun was pinging their server, but I haven’t heard anything lately…
@madas, since you’re experiencing these problems you might want to publish (in your Profile footer) the list of devices you have hanging off Vera as other do here. Perhaps also the Dongle version, in case that’s not upgraded or whatever.
Given past discussions on hangs (etc), there may be a pattern based upon the specific ZWave devices present in a given network. Mine are almost all Leviton (or Leviton OEM) and the network is completely stable, always has been.
As a [broad, general] rule, the more centrally gathered data on software problem occurrences, the easier it becomes to debug it, as you can often see the patterns more clearly.
So, if there was only one thread on “Vera lockups”, and everyone posted their config in their Profile, as you now do (thanks!), then we might start to see a pattern and help MCV’s team diagnose/isolate it a little.
It doesn’t always work, but it can certainly help.
Unfortunately the other lockup thread (if i remember correctly) is in reference to the dongle lockup, which doesn’t happen for me.
Although I agree, single thread makes things much easier. It’d be better if we could access the bug system directly so that we can all contribute to the same tickets.
