433mhz Window Sensors
I have some 433mhz window sensors on the windows from at&t digital life security system and i was wondering if there is a USB adapter I can buy and use it with my Vera lite and be able to control them?
I saw my Vera lite has an USB port on it so i tough will be a good idea save some money, each z wave window sensor cost way over 30$ and i have more than 15 windows in the house.
Thanks …
You should check if your window sensors are compatible with the RFXtrx433 USB interface. There is a plugin for this device that can be used if your on UI5.
I will, thanks for your help
Were you able to determine if the ATT Digital Life sensors are compatible with the RFXtrx433 USB interface?
