4 in 1 aeon multi sensor and UI7
Has anyone been able to get this to work with UI7? The motion is the only thing that appears to work. It knows it’s suppose to read humidity, temperature, and light sensor but doesn’t show any values. I have tried deleting, unpairing, and adding again. I tried battery power and I tried USB powered.
Thanks,
Wes
Is it the Gen5 version of the sensor or the older one? I have had the old version of working on my Vera Edge UI7. The only problem I have had is false triggers of the motion sensor which is a suspected hardware problem of the sensor. I am now waiting for a replacement sensor.
Sometimes I have realized that it takes some time for values to show up when a page is loaded in the UI. I don’t think it is anything specific for the Aeon Labs sensor though.
I wrote a possible soluton here
http://forum.micasaverde.com/index.php/topic,29861.msg223507.html#msg223507
