How are you progressing in your quest?
I’m curious to hear what you end up doing as i too have an image in my head of some kind of overlay to my tv that will pop up events, information as a when things are triggered.
@Aaron, I have been messing around a bit with Python Twisted code that grabs Vera userdata in JSON format (following the UI Simple example) and puts it into a SQLite database. My code is still pretty ugly and there are things that don’t work yet, but I have done enough to know that it should be straightforward to integrate a Vera plugin into Maraschino. You would have to use threads instead of twisted I think from a quick look at the source code.
I’m using a slightly different route. I also want a master front end for my Vera and various other things in my house (Denon receiver, Squeezebox players, XBMC or PLEX, and Windows Media Center). I love my Vera but it doesn’t have quite enough umph to control everything I want to do through it and it is too much work writing all the interfaces myself.
I am probably going to use EventGhost along with the new EventGhost Websocket plugin. One of the EG developers (Pako) put togeather a demo that I’ll probably start with and combine with my own Python Twisted based backend: Event Ghost Websocket Suite.
