Hello,
After adding my second 3 in 1 sensor, the child devices are not created. Whats wrong? The device was reset / removed before adding. There were no problems adding the first 3 in 1 sensor.
Using vera 2 ui4 firmware version 1.1.1362
Hello,
I guess you already reloaded the lua engine a few times…
Maybe try clearing your browser cache and reloading the UI will help.
Which sensor are you talking about?
It may have gone to sleep before Vera had the chance to find out what type of device it was.
Try waking it and using the configure node now button. I guess it may still be listed as GenericIO device perhaps?
Configure now worked. Thanks.
