I have created a scene that will turn on a series of lights 30 mins after sunset, however, it doesn’t seem working.
There are four kinds schedules: 1. Interval 2. day of week based 3. day of month based 4. absolute
I have tried first one which works but I have to manually write some conditional statements and the run every 15 mins is kind of annoying as well. so I started wondering if I could use 2nd type schedules to automatically determine the sunset time every day, then I don’t have to trigger the scene every 15 mins to just turn on the lights once a day.
So long as you have your Vera set to the correct location then the attached should be all you need to do for your schedule.
Hi, Thank you!
I did exactly the same thing! and I double checked the location setting, it is correct as well, I will keep monitoring for another day, gues it was vera traffic issue caused missing execution?
It was running ok today, I guess my vera 3 unit was busy doing other stuff on that moment yesterday around 30 mins after sunset, so the execution point missed, I will keep monitoring this. Thank you to 2nd floor!
