3 Flashes on Dongle when adding device
Hey folks,
Question about adding a lamp module. I have added a number of lamp, appliance, and dimmers but this is the first time I have gotten 3 quick flashes when trying to add a device with the dongle and not the 2 second long flash that is supposed to show up. Needless to say, it does not show up in vera when I plug the dongle back in.
I have reset the device using the right procedures and I get the 2 second long flash to confirm the reset of the lamp module, but I just can’t get it to add properly.
Anyone know what the 3 quick flashes mean when trying to add a device?
I have gotten that before when trying to add an HSM100 to Vera. Just assumed it meant failure, reset the device and was able to add it then.
My only advice would be to reset the device again using dongle , plug it back into Vera, let Vera reset, then take the dongle out again and add the device. For some reason if I did not plug the dongle back into Vera I could not add the device properly.
Sweet! You’re the man. That worked. Don’t know why I didn’t try that.
I still didn’t get the 2 second flash.
-I entered remove mode on the dongle.
-Activated the Lamp Module to remove
-Dongle flashed 2 second flash
-Plugged dongle back in to Vera and waited 60 seconds.
-Went back to lamp module with dongle in add mode
-Activated the Lamp module to add
-Dongle flashed quickly for 6 to 8 seconds (like it was in remove mode) and then it gave me the solid 2 second flash.
-Lamp Module shows up
It shows up as a dimmable switch (don’t recall if this is the way the rest of the lamp modules were treated or not).
Not a smooth fix but it works. Now if I could only get that Schlage lock to work!
Thanks!!!
