2nd Genaration H@L - Android Only Voice Recognition for Vera
It works. I will send you the files for “fr_FR”.
You can also customize the other files with the .config extension
Content.config controls the help file generation. You should include your changes for Semantics.config here … so the help file will be localized correctly as well … Also the OrigHelp.html would need to be localized … this is the generic instructions.
Active.,config controls what is considered active.
Status.config controls what the status message for a device is, and how it is spoken.
Name.config controls the names of the DEVICE classes. This is used in wild cards were you want to issue a command to ALL devices in a class. It is also used in the help file generation.
There are a few things that I am sure I forgot to localize … let me know what you find.
Of course we can also localize all of the App menu entries …,. I can send you a file for that as well … it’s not in the reference area.
When an update is made … it will NOT change your modified files … so they will survive an update or uninstall/install cycle.
You must manually delete them to get back to stock!
I would appreciate any comments on the overall customization process … You are the first … Bucko ran into some problems,
A question I have is should I add an option to HAL to specify the translation language or default to the phones setting (As done currently) ?
When people use Google recognition in other languages … do they often speak in different languages for different apps ?
Richard,
How do I say to Open ( Close ) the curtain, I tried it and it recognised my words but vera just not doing anything? Right now, I need to setup another scene and run the scene in order to open ( close ) the curtain. But this is not very convenient if I need to open 30% , close 80% of the curtain.
Richard - Any plans to integrate with Google Home?
Yep, I have a Google Home, but parts of the API are not available until December.
What is the command for the curtain? H@L find the curtain but up/down/open/close don’t do nothing… in http if I use http://192.168.1.205:3480/data_request?id=action&DeviceNum=22&serviceId=urn:upnp-org:serviceId:WindowCovering1&action=Down
the curtain regulary close… please help…
