2gig ZStat Problem with Yellow Battery Icon
Installed a 2Gig ZStat C30 6 weeks ago and paired to Vera. It is hard wired to 24 volt wire to heat pump and installed new batteries. Everything has worked properly for 6 weeks. Yesterday I noticed from the MIOS Dash that battery Icon had a (?) inside and was now yellow. Tried to change the temp setting and nothing worked.
I ran the "heal"system command and now all battery icons look yellow with the “?” inside.
The Vera system dash will not show status of any device on my system.
I also rebooted my system from the advance tab with no luck of correcting anything.
Called tech support and they could not help. Can anyone point me in the right direction? :cry:
