240 volt z-wave devices
Does anyone know where I can get z-wave devices that work on 240volts power input?
Sent from my HTC One using Tapatalk
Depends which country you are in. All the European ones are 240V. If you post which country you are in people will be able to help
There are a number of 240 volt devices available from various suppliers depending on what country you are in.
In the UK I have used the following:
There are a number of European stores as well which can be found by googling “z wave Europe”
Regards
Nick
Great. Thanks tetleyn. I would check out those two links
I’m currently living in Ghana, West Africa. But I mostly shop online on amazon.com since most of my family lives in USA
Those UK zwave devices aren’t going to work with US devices:
http://z-wave.sigmadesigns.com/docs/Z-Wave_Frequency_Coverage.pdf
Oh OK. The UK z-wave veralite is so expensive. If only I could configure the us veralite to connect to uk devices which are also expensive
See your signature.
See your signature.[/quote]
Hahahahahahahahahaha!!!
