I have exactly the same issue. Qubino has the smart-meter series with two types of switches capable of a max 32A load which is pretty high. They’re din-rail switches and you must link them with the Qubino smart-meter which carries the z-wave chip. That absolutely fits my need but I see no support from Vera for this type of devices.
that will not work for me, i want something as a normal wall switch that i can install in a normal room as a normal wall switch or a device that i can put behind the wall switch.
I’m afraid you will have to build such a switch by using a relay + zwave switch. The relay will take over the load while zwave (like fibaro fgs221) switch the communication with your controller + an external switch when your zwave is off for any reason. Please don’t do it yourself if you’re not experienced enough with high voltages. Call an electrician instead.
thank you all for the input, the relay will work, actually i brought a relay already, but i was searching if there is a switch that can handle the load without the relay.
the heavy duty zwave will work too, but my question is, is it reliable to have them this way, i mean one dummy zwave switch to trigger the heavy duty?
I use a 10amp zwave relay to activate a higher rated relay provided by my electrician that boosts my hotwater system… has worked flawlessly for a year.
