2 Vera?s with 1 account
Can you advise if I can use a Vera Plus and a Vera Secuirty with one account?? The 2 systems will be used for 2 houses- 1 in Spain 1 in UK, so on separate networks-
I would want to use the same account credentials for both systems but wondering if this would be an issue
Adrian
Yes you can. You can have as many controllers on your account as you want.
