2 gig ct100 programming problems help
Hello, new to MCV. trying to figure out how to set up thermostat schedules throughout the day and week (vera lite module with firmware upgrade) through MIOS on my 2 gig ct100 thermostat. unable to figure out how to program this thermostat through the internet access. i know this thermostat has the capabilities since i am able to program through alarm.com without problems on a separate system. if anyone believes that it is NOT programmable is there another thermostat z wave suggestion that will integrate better on the programmable level. need to have different cycles throughout the day to control humidity in the south. thanks in advance for any help out there
You don’t describe the components of this “separate system”, but it must have included a Z-wave controller if it was controlling the CT100, as that is the only remote method of communication that it has.
It has no internal scheduling capability. Any schedule must be implemented by the device controlling it (or the service controlling the controller). Scheduling can be done via Vera, but it's can be pretty convoluted if you ask me.
The CT100 is a good thermostat, if you understand its limited capabilities. If you want IP control and internal scheduling, then you might consider one of its siblings from Radio Thermostat/2Gig/Filtrete such as the CT30, CT80, or 3M-50 with the WIFI module. There’s a Vera plug-in for the WIFI mode and scheduling/control via a free website and/or tablet app. A public API allows control of almost any function. The Ecobee is also a popular thermostat with WIFI control and a Vera app.
i’m in the same boar. Have a CT100, the device shows up in Vera Lite, but i’m unable to set temprature points for different times of days & the days we are home
I would like to set night to 64 heat/ Morning to 72 / Day to 64 / Evenings to 73 except weekends where i want the day to be 73
Any idea how to accomplish it ?
thanks
Check out this post, or perhaps PLEG if you’re ready to dive in head first.
I bought this thermostat and just finished setting up a schedule for it. Since I have not seen my simple, obvious approach documented here, I will do it here for completeness.
I just set up two scenes, one for day and one for the night. I could have done with just one scene if I had used the delay feature, but I like the run button in the scene as it allows me to adjust manually when to shift between the two.
So for a simple schedule for every day of the week: at midnight Heat 64, Cool 83; at 7 AM Heat 70, Cool 79
Create a scene and for the device include both the heat (red) and cool (blue) plus/minus scales and set the red to 64 and blue to 83. Then create a schedule for it for every day of the week at 00:00:00.
Next create another scene and do the same for the device but this time set the red to 70 and blue to 79. Then create a schedule for it for every day of the week at 07:00:00.
And that is it. You can test it by using the scene run buttons. If you want only one scene, configure a seven hour delay into the first scene and for the device set the temperatures appropriately.
For batrad’s more complicated schedule he needs a minimum of two schedules, one for the weekend and one for the weekdays. Then he can set up delays for all of the times in a day he needs to change settings and set up a schedule for the appropriate days of the week for the first time change. If he does not want to set up delays, he would end up with four scenes for the weekdays and three for the weekends.
I also tried to run the thermostat in Auto mode, but it makes it confusing to change the target temperature, and impossible if the thermostat is half locked. So I set it for Heat instead and added two scenes, Heat2Cool and Cool2Heat that just have a trigger each. So if the current temperature goes so high that Cooling should engage, I switch the Mode to Cooling, and if it drops so much heat should kick in, I switch the Mode to Heat. I have not tested this yet, but it was easy to set up and I think I got it right.
Karik, how did you get it to show and respect the Heat and AC setting? I can only seem to make it do one or the other.
Ideally, I would like to write a script that looks at the mode (that I would manually set) and adjust the Target Temp based on the mode (say 5am; 68 in Heat mode and 78 in Cool mode).
Which plug-in is it?
Here’s LUUP code that queries the 2 thermostat set points and updates them. Change the device id to match your thermostat. This should be effective even if you are using UI7. (I’m still on UI5 because my main purpose of Vera is to control my thermostat and I want to access both set points).
local device=57
local hot_temp =luup.variable_get(“urn:upnp-org:serviceId:TemperatureSetpoint1_Heat”,“CurrentSetpoint”, device)
local cold_temp =luup.variable_get(“urn:upnp-org:serviceId:TemperatureSetpoint1_Cool”,“CurrentSetpoint”, device)
local new_hot_set= hot_temp +3
local new_cold_set= cold_temp +3
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Heat”,
“SetCurrentSetpoint”, {NewCurrentSetpoint = new_hot_set},
device)
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Cool”,
“SetCurrentSetpoint”, {NewCurrentSetpoint = new_cold_set},
device)
I use the table driven code that is in the link above. It has worked great for a long time and allows me to create as many different setting as i want. the primary trick it calculating what a specific time is. I had it in a scene but have now moved it to plug. Follow that link and don’t forget to change your device number.
So what is the standard thermostat everyone is buying and from where? 2gig CT100 from Amazon?
Requirements: big numbers, lights up at night when i hit a button, talks to VeraEdge, forced air gas heat, central air, ability to run the fan only, not buggy… I have a 4 wire now, but planing to pull an 8 wire soon.
I have the CT101, aka the Lowe’s IRIS thermostat. Supports 2-state/2 mode heat, 2-stage AC, fan-only, touch screen, lights up, has a base program, and talks well to Vera. (I have a Vera2 on UI5).
I had the CT100 for about 5 months. I had a program setup with LUUP code and it worked OK. My wife hated it if she took a day off she normally worked, she’d adjust the thermostat and 5 minutes later it would go back to its programming. She didn’t like having to go into the Vera and disabling ALL of the thermostat scenes.
A few weeks ago my electric company sent a letter saying they’d pay for up to $150 on a Honeywell wifi thermostat. I got the nice color touch screen one and am only paying $22 for it out of pocket. I just installed it last night and it works great so far. I can still control it in Vera, My wife can override the programming for any amount of time she wants. It just looks nice too. I don’t regret it one bit. So much less hassle. I was already thinking of buying it before the rebate from the power co, but once I got that, I immediately jumped on it.
[quote=“benk016, post:12, topic:178193”]I had the CT100 for about 5 months. I had a program setup with LUUP code and it worked OK. My wife hated it if she took a day off she normally worked, she’d adjust the thermostat and 5 minutes later it would go back to its programming. She didn’t like having to go into the Vera and disabling ALL of the thermostat scenes.
A few weeks ago my electric company sent a letter saying they’d pay for up to $150 on a Honeywell wifi thermostat. I got the nice color touch screen one and am only paying $22 for it out of pocket. I just installed it last night and it works great so far. I can still control it in Vera, My wife can override the programming for any amount of time she wants. It just looks nice too. I don’t regret it one bit. So much less hassle. I was already thinking of buying it before the rebate from the power co, but once I got that, I immediately jumped on it.[/quote]
If you don’t mind saying, which power company was it?
Good deal on the rebate! What modle is the Honeywell? I see a few models, TH8320ZW1000, YTH8320ZW1007, RTH8580ZW and ZWSTAT. They all look similar.
PSO In Oklahoma
RTH9580WF It is a WiFi thermostat instead of ZWave. I was so disappointed with how Vera controls HVAC that I decided to get a thermostat that could schedule itself. It has 100x more functionality than the vera. I can still access it in the Vera interface, but all the actual schedule programming is done on the unit itself.
