2 Foscam Cams, Vera shows 3 -- how do I remove the duplicate?
I have 2 new Foscam 8910w cameras. They seem to be detected and work properly in Vera (shows both video and motion devices for each cam) BUT on one of the cams I get duplicate Motion & Video devices… if I try to delete them it tells me it will delete the plug too… help please :slight_smile:
If you have problem to delete the cameras use this link:
http://:3480/data_request?id=device&action=delete&device=
[quote=“HouseBot, post:2, topic:173045”]If you have problem to delete the cameras use this link:
http://:3480/data_request?id=device&action=delete&device=[/quote]
worked perfectly, thank you!
This solution does not seem to work for me. It just comes up “ERROR”. Any other suggestions?
