I installed the latest on openLuup via the alt plugins page. The existing sensors open fine without error, however, creating a new sensor shows the following errors as seen in the attachments.
OK. Got those. Without posting any updates, your first error should go away if you restart the sensor or restart Luup. If you wish, you can pull the new/updated stable branch version of just J_ReactorSensor_UI7.js. It now has both fixes.
THANK YOU!
OK, updated the code and all looks good so far.
