1.5.662 Not available
I am unable to get my Vera to see the new firmware as available for update. Is the new firmware released or not?
How are you trying to get to the new firmware? Have you seen this post?
http://forum.micasaverde.com/index.php/topic,13956.0.html
  • Garrett
Yes, and I used the link. It says: You are trying to upgrade to an outdated beta version which is no longer available.
Go to Upgrade
This was detailed in the thread @Garrett pointed you to - see
http://forum.micasaverde.com/index.php?topic=13956.60
I have been unable to properly configure one of my two Yale door locks. The one farther away from the Vera 3 is configured perfectly, but the one in the same room with the Vera, about 8 feet away, will not configure. Most things actually work – I can set pin codes, I can open and close the lock – but Vera always reports that the lock is open.
The web-based dashboard reports that I have firmware version 1.5.408, and I have read that that version has some problems with Yale door locks. But the dashboard says that 1.5.408 is the current version, even though apparently there is a new firmware version. I tried going through the web firmware upgrade portal, but it said that it could not find a vera on my network.
Any advice on whether I should upgrade the firmware, and how?
Rodney Pearson
rodney.pearson@msstate.edu
