[quote=“nwrunner, post:3, topic:168460”]After repeated requests to support I still cannot get an answer whether 1245 is compatible with the Harmony 890 pro remotes.
Someone in the progressions thread indicated their remotes would no longer communicate with the dongle.
Any ideas?[/quote]
I havent done this personally but the remote control server stores the useraccount info in this file:
/etc/cmh/users.conf
How do i enjoy the benefits (some necessary like making devices work properly) contained in this new firmware update, WITHOUT UI4/connection to findvera.com?
The furthest ive seen anyone get is disabling the tunnel to findvera.com but other services and functions still maintain/use your login to findvera.
Is the current install base really OK with the idea of our boxes becoming bricks if for whatever reason they cannot call home? In addition, whats with the extremely weak passwords?? Inexcusable!
Check out this thread. The beta UI that Timalls has built works quite well as a controller. It doesn’t do everything that UI$ does-yet. But it is local control only.
[quote=“hightop32, post:8, topic:168460”]How do i enjoy the benefits (some necessary like making devices work properly) contained in this new firmware update, WITHOUT UI4/connection to findvera.com?
Is the current install base really OK with the idea of our boxes becoming bricks if for whatever reason they cannot call home? In addition, whats with the extremely weak passwords?? Inexcusable![/quote]
