1.0.987 Not Found error at findvera.com
Anyone else on 1.0.987 getting:
Not Found
The requested URL /remote 1.0.987/ was not found on this server.
when trying to control via findvera.com?
Yeah, I’m getting that error too. It seems to happen after every new firmware version is released, and MCV has to manually do something to fix it. The same thing happened with the previous firmware version.
FYI - if you revert to 1.0.985, then FindVera.com will work again. That’s what I just did as a temporary workaround.
I’m really sorry about the problems with 985/987. 979 remains our last official stable UI2 release, but we needed to rush through an unscheduled UI2 build (985) for the Square Connect iPhone app beta testers who didn’t want to use UI3. It was unexpected because we were expecting all of them to use the official UI3 release. Anyway, we discovered this morning a small issue in the .987 build preventing the UI from updating, which was caused by a small API change that was written for Square Connect for UI3 which hadn’t been tested with the UI2. I will ask our testers to test this 988 build on Monday, but, in the meantime, it’s been reported that it solves the issue: [url=http://download.controlmyhouse.net/betafirmware/ftp/wl500gP_Luup_ui2-1.0.988-1.trx]http://download.controlmyhouse.net/betafirmware/ftp/wl500gP_Luup_ui2-1.0.988-1.trx[/url]
MCV,
The new firmware (988) works great for me. No more reboots, the UI updates as expected, and FindVera.com works perfectly. Thanks for the quick turn around!
I saw that error as well. Upgraded to 1.0.988 just fine but … when I made a change to a scene and saved, Vera just hung. Anyone else seeing this?
