1.0.918 >>>1.0.899
Has anyone flashed Vera 1.0.918 back to 1.0.899?
I never tried .899 and I don’t need the X10/insteon.
I can tell you I am on 0.900 right now and that has been pretty stable for me.
I have not flashed back to the specific versions you are listing, but I have gone backward in versions in the past by reflashing, but that was pre-LUUP.
where can I get .900
For any version you just need to edit the download link to have the version you want in it:
[url=http://download.controlmyhouse.net/betafirmware/ftp/wl500gP_Luup-1.0.900.trx]http://download.controlmyhouse.net/betafirmware/ftp/wl500gP_Luup-1.0.900.trx[/url]
I did… for me 899 is much more reliable than 918
I may end up downgrading from 918 myself - I started seeing long delays (5-10 minutes) for commands, as they get queued up for that long for some reason…
@denix
thats good news to hear I am not the only one with delayed commands in 918… i was starting to think I was the only one with that problem.
can you do a soft reboot from within vera and the problem goes away?
Don’t know about soft reboot. But the problem is intermittent - it comes and goes. The long queue of commands/polls is gone and works fast again. It’s been up for over 3 days, according to uptime.
I just did a build which should fix this, assuming the cause of your problem is the same as what we identified. We’re doing the full set of tests now and should release it soon. The link is: http://download.controlmyhouse.net/betafirmware/ftp/wl500gP_Luup-1.0.937.trx if you want to try it out
Thank you! I am now trying it - let’s see how it works longer term, as 15 minutes is not an indication… :slight_smile:
