[0.978] Lost all graph and data with update to 0.978
With the update to 0.978, I lost all configuration and data. (the original data is still in the datamine directory). :o
Something went wrong with the database conversion.
Probably this is due to the update happened when a Z-Wave ‘repair’ and ‘heal’ command was in progress (auto-update was checked for the datamine app).
Is there a way to rebuild the configuration/database?
The system should recover from restart like you describe, but…
there’s a variable in the config file that can retrigger the transfer. Unfortunately I can’t access the Internet at the moment (except on my phone) so I can’t find it (sorry). I’ll see if I can access this at work tomorrow.
Chris
Can you give the filename, location and parameter?
You don’t need explain in full detail about logging in, and the use of Linux commands. I’m a Linux user, so I know the basics.
